When is it necissary to get a new alternator?
When your average amperage draw (taking into consideration the constant needs of the car itself plus audio gear) exceeds the continual capacity of your alternator.
You have to keep in mind that the current your system could draw at full tilt isn't nearly the same thing as what it will require for your average daily listening.
Example - my monoblock can draw 160 amperes of current by itself. In its current configuration it won't, thankfully.
most people I know say that you probably need a new alternator once you go over 1000=1200 watts. but I would imagine it varies with the vehicle
Absolutely.
My car's stock rating for the alternator was 75a PEAK output before I had it rewound.
Much more than a 50w X 4 amp gave me major dimmage before. I'm good to go now, though, with 165a continuous output in a stock case //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
this is very true, my mercury had a stock alt 115amp max 65 at idle. when i had my colossus' gains set at 2000 rms the alt kept up like a champ, light dimming with stock battery and big three in 0 gauge, now i got an iraggi 240
really depends on the condition of your alternator. like talon said above, a good conditioned alternator may last a long time before it craps out on you.
onearmedbastard
Balls deep
onearmedbastard
Houston
audioholic
