dannyz122001
when inverting 1 of 2 subs, i know that you need to reverse the polarity of one to keep it in phase with the other (normal) mounted sub. however, my question is, when inverting 2 subs, do i need to reverse the polarity on both?
also, i am planning on flush-mounting the inverted subs. so i will make a trim ring so that the entire perimeter of the subs is enclosed in the ring. but, do i simply use the same cut-out hole?
lastly, is there any sort of gasket or sealant that i should/need to use?
thanks for all help
thanks for all help
