Whats this called and where can i get a replacement
It's a type of terminal/barrier strip, but I doubt you'd find one like that anywhere other than from the manufacturer.
i would think they would be universal, is their any suggestions out there on another way to go around fixing maybe directly solder to the terminal
That is a power/ground terminal. I was looking for some a while back. No luck. The only way to get them is from the manufacturer, or a similar broken amp. If you can find a site that sells:search: "oem electronic parts" you might have some luck. Google is your friend. Good luck:eyebrow:
woc47
That's How I Roll
woc47
Orlando,FL
electropro
