Whats the point of Huge VC on low RMS speakers?
Lower inductance, greater BL, better cooling.. there are only advantages to using a larger dia. coil even with the same amount of copper..
My Opti 6.5" mids have a 3" voice coil.. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Le would be higher for a larger diameter coil due to more wire being in the gap.
But as was said....even though it's "low power" compared to a subwoofer, a larger diameter coil can improve power handling (and more importantly reduce power compression). Also, the diameter of the coil affects how the former attaches the cone, which can affect cone resonance and stability.
Just because it uses a 3" coil doesn't mean that it's built like a 3" coil that's on subwoofers. The coils on a mid doesn't need to be as long, and I doubt here are many, if any, mids that have 4-8 layer coils with as thick of wire as normal subs use.
Larger coil also means lower sensitivity(assuming the overall mass of the coil is higher).
A different pair of 3" vc morel mids (not uniflow) reviewed
poorly on Zaph because according to the review, there was
not enough spider to back it up.
why would there necassarilly be any more wire in the gap ? If both are underhung that wouldn't be the case, and if they were overhung the topplate would be different, accordingly...
that said you are either making arbitrary statments or compairing apples to oranges... If you look a the coils alone a shorter wrap on a larger dia former will have less inductance, which is my point...
splduck1978
splduck1978
Clovis NM
audioarsonal
