What's the best way to patch 4 awg together?
The best (most secure) method that I can think of would be to incorporate an inline fuse holder in the cable path. Safe, secure, no need to worry about a splice coming apart, etc etc //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I did think of that but I would rather not spend $10 on fuse holder just for that. How about using about a 1" piece of 1/4" copper plumbing, crimping it, heat shrinking it, and taping it off really well??
I recommend stripping back a sizeable length on each side... say a little over an inch. Meet the ends, and braid them together. Then I usually use an Acetylene Torch, and solder the hell out of it. I will usually use heat shrink tubing over it after I'm done... and then also E-tape the hell out of it...
nG
nG
Good idea thanks....anyone else?
nG
Beat me to it. Thats what I was going to suggest.
Soldering is the best idea its the cleanest looking when done and keeps the best power transfer... the easiest way to connect them would be to take a couple of ring terminals and put them on the two ends u want to connect then used a nut/bolt to join them and tape the sh*t outta it.
i spliced using a big *** wire nut on some 8 gauge then E taped the shit outta it so that i knew for a fact that it wouldnt come undone... power transer and everything is fine and its cheap 30 cents....
pwer transfer is probably good but i'm sure their is at least a small voltage drop across the connection.
nG
good idea if you already have the torch, if not then it will cost $20 for the torch kit, which is what a 16' piece of 4ga will cost //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
FoxPro5
Causal wanderer
FoxPro5
3 octaves higher
MustangGT25YRS
