what's the best amplifier for 2 sundown sa12s for under $270 ?
almost the same as the ph4000, is the vfl 4480.1 hybrid. i have that amp on 2 sa 12s right now. it does pretty good if i say so myself. i havent clamped it, but the subs shake the **** outta my car!
only mentioning it as you have two amps to choose from price wise. seems like identical amps.
i made a short video for a buddy out of town playing "im different - by DJ Slowfets"
just uploaded it
the amps tucked down behind the seat, you can just see the top. my box is also on the small side, at 3.8 cu ft @33hz
Edit: 3.5 cu ft after subs displacement
you're going to need a 2-3k amp to get 1500w rms after rise out of it, if you're going to wire down that might help but .5 ohm stable amps are also expensive.
you can get a hifonics brx/z2400 but dont expect more than 1500 out of it unless you wire down and id definitely not recommend wiring down without a lot of electrical
mine is wired at 1 ohm, but "guessing" amps seeing 2.5ohm after box rise. so again guessing, im gonna say 1200w rms after rise..
fk amp rating.. cant go by that. look up box rise, and how it fights amp impedance.
2k after rise would be great, but youll pay for it..
edit: mitchell0715 was correct, and i completely overlooked his post about box rise.
that said, ive read the vlf4480 is stable at .5 ohm with proper electrical.
Im guessing thats atleast 3 agm batts..
minhazul
minhazul
Dhaka ,Bangladesh
poolman966554
