what's port tuning?
i used two 4'X2'X.750" and two 4'X2'X.500" sheets to make the box. i had left over wood after all the cutting was done. i glued the two .500" sheets together to make the 1.000" front baffle. everything worked out great. hell, i even routered the begining edge of the port inside the box to get that nice rounded edge. i also used t-nuts for mounting the sub so there will be no stripped out screw holes.
word. did you do the cuts yourself?
nice. what did you tune yours to?
now did you read the title of this thread?
i have no clue. i built the box to jl specs and it is what it is. now i started this thread to find out what port tuning is. since i built the box the way they wanted i assume it's tuned to 32hz.
LOW ET
LOW ET
cleveland, ohio
LOW ET
