whats best way to wire this up
Harleyfx69
audio n00b
im looking to have 3 amps in my setup,
1 kicker for door speakers,
and 2 audioque's for sub stage,
what power wire do i need to run,
what wire do i need for door speakers
what wire do i need for subwoofers ,
then im also guessing a distro block for the amps , then the turn on lead for the HU ,
im surmising that a suitable wiring would be as follows,
1/0 from battery to distro block,
3 4 gauge runs from distro to amps,
then 10 gauge from amps to speakers and subs,
or would i need two runs of 1/0 to the distro block to run all 3 amps ?
what are the fuse ratings on the amps?
and for door speakers 14 ga speaker wire should be fine....in fact, 16 would even work.
Run the largest wire you can afford (that’s what I tell my customers)
With three amplifiers; you should be considering adding another battery
Install the auxiliary battery near the amplifiers, if possible.
got dual batt's already, along with a HO electrical system, and after i get it all wired in .. im considering runnin the 0 gauge in the engine compartment .. but im hoping thats not necesary as it will be a major PITA ..
Harleyfx69
audio n00b
Harleyfx69
arizona
Harleyfx69
