whats a subsonic filter
In laymen's terms //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif A subsonic filter blocks frequencies below the audible range. So your amp doesn't use the extra power trying to reproduce them. It also helps keep your sub from over excursion due to the low frequencies. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no, you NEED a SubsonicFilter if you are going to use a ported box. it damage them subs if you don't, because your box wouldn't be tuned to be THAT low.. dam 20Hz and under !!!//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif if you are going sealed, it's not imparative you use one
Originally posted by Goddyd4me instead of getting a subsonic filter wouldnt a crossover work? basicly the same thing right?
A subsonic filter is a High pass cossover. Most high pass crossovers don't have crossover points at 20hz. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i listen to all kinds of music on it. rap, rock, techno, bass tests, and it hasn't crapped out on me yet. it is in the back of a cherokee so i can hear distortion and know when to turn it down.
i think a SSF cuts off points below what you set it at... i never thought it would go ABOVE what set it at, that's what a regualr X-over does... and b4 they said SSF's were "reverse x-overs" meaning it cuts below what you set it at.. thats why you want them in ported enclosures
Okay I think we are all getting a little confused.
A high pass crossover let's frequencies above the cutoff point through.
A low pass crossover let's frequencies below the cutoff point through.
A subsonic filter is a really low high pass crossover. It filters out the sub sonic bass below the cut off point. Depending upon the model it's usually somewhere around 20hz. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by HX2 How often does music actually go below 20hz. tho?
Actual music -- not very often //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Most doesn't even come close.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
SQcivic
SQcivic
Denver
more_spl
    Jun 15, 2024
    Jun 15, 2024
