WHATS A BAD *** SUB AMP IN THE 5 TO 10k WATTS RANGE?
My new set up is 2 15 hdc315-a with 5k rms each in a 5 cb foot box after dissplacments w/ 2 or 3 6inch aeros //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you're seriously interested in the brazil amps (sound digital/stetsom) I can hook it up.
Could also look into the Sundown 4500's. I might run some on an 18v setup.
And they also don't need to be ran at .5ohm to make their power.
And op, you said your electrical is upgraded. Please specify.
got 5 135amhr powerware batteries (100lbs ea), resting at 13.5v, 1 k2400, 200A exterernal adjustable voltage regulator, 2 runs of 4/0 from the alternator to the back batteries, and all 2/0 running from the batteries to the amps. 8 guage remote wires, 8 guage speaker wires.
Need One Thats Reliable As Hell And Can Handle The .5 Loads
I'd look into the Cactus Sounds K5. They are supposed to be stronger then the older Team CS5kW on limited battery power(and I love my old 5kWs)
The CS K9 and CS K9S is also something to look into. They have been tested against the bigger (or biggest) amps on the market and do about the same power on limited (and possibly unlimited) battery setups.
sub-FATHER
Resurecting this sport
sub-FATHER
denver, CO.
pawn man
