What
The entire interior of this car has been gutted. Sandblasted To bare metal... deadend from floor to roof with 2 layers 80 mil. then Insluated floor to roof with felt .drilled every pillar and filled with spray foam... and all new wether stripping and seals all the way around.. i left no stone un turned "IM ALREADY PULLED OVER!!! I CANT PULL OVER ANY FURTHER!!!"
The hard clacking you here is mostly the ragtop mechanism
Cant move the box at the moment for it is bolted threw the firewall
I will be picking up that ssa db meter in a few weeks. Then i can really start moving things around and look for my best number
Put resin on the roof dammit. Lol
Edit didn't notice it was a soft top. Disregard my comment
Resin with crack and break off. Need to use mat and resin and it might work. Best luck we have had is 1/8th wood with a felxiable adhesive. Then another sheet of wood with wood glue and then another sheet with wood glue untill it's pretty thick and strong... my other buddy just welded 1x3 steel to his roof and now he blows windshields because the roof doesn't move at all and the pressure goes to the windshield, the best thing to do is make the roof strong but still alittle flexible.
If you use the correct resin it wont. It depends on the bind..
My63bug
My63bug
Vacaville ca
My63bug
