What would you choose?
Choose
  • Total voters
    21
Orion 2500d-dependable, proven stable to .5ohm daily
Crossfire VR2000D-I have never use but I hear really great things on this amp,
Viper D2500.1-decent, internals look well planned and beefy. Only 2ohm stable. I remember reading ScottyJ talking about them, ebelive that he said the amp wasnt stable
Directed 2400d-basically the viper, dont know the specs, dont really care to.
I would have to say either the crossfire or the orion.......A local caraudio shop, actually the one alpine installer works at, used to sell crossfire products and a previous owner had a comp. vehicle with only crossfire audio in it. I must say those are some dependable amps. And orion they have always been strong and reliable amplifiers. The other two are also very good amps too.
What on earth does that meen?
Probably that it doesn't do a whole lot of power below rated voltage...you'd need a pretty constant voltage level to get the most out of it.
But then again, I've never used a "Catchfire" amp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dont forget Mmats,Memphis,and US Amps - all of which I think are better than the above mentioned
well crossfire is a lil ahead of memphis. Cus memphis is has its stupid fuses on the bottom of the amp. Which means you have to demount the amp to change the fuses. BUt i would go with crossfire. THey are solid amps.
Orion or Viper. But probably the Orion because it is 1 ohm stable. But i had to mention Viper because i have 2 1200's and they are awesome amps i have had these amps for years so they are dependable. But no matter what out of them you will get what it says and more the Crossfire is probably the most underrated but also the most expensive. The others can be had pretty cheap.
tRiGgEr
tRiGgEr
San Diego, Ca
iceteebone
