what would you charge?
$1000 is what I would charge for a job like that and that may even be to cheap. But I would charge a $1000 just labor plus supplies which I would mark up.
Yea I would say at LEAST 1500-2000 in labor charges... that is not including the cost of the materials you'll need (if you are buying all the equipment) and then I would quote him like a weeks worth of work to make it easy for you to get it done without being rushed..
Andrew
definitely is a HELL of a job
the sound deadening in itself is a *****, as well as installing all the componenets and the wiring
it will take u a WHILEEEE so u better tell him to expect it to be a lot
hopefully there will be more than 1 person working on it
Well, also take into consideration the quality of work he'll receive. I haven't a clue of how good/bad you are, but you do, so I guess be fair.
With the numbers being thrown around at this point, I would definitely get a deposit up front. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
heavily depends on HOW MUCH sound deadening....
most audio shops would charge a grip for sound deadening... 36 sq. feet = $125-150+ (install-- its more or less what i've seen audio shops charge)
Also don't over-extend yourself and give him a low price where it WON'T motivate you to finish it and do it correctly. Labor is an important part of every install, let him know that.
sinosic
Idyllic Enclosures
sinosic
roseville,ca
Stem
BP1Fanatic
BP1Fanatic
