What would cause 0 voltage on preamp outputs?
  • 4
grampi
Cheyenne
I've checked the obvious things like making sure the HU wasn't muted and defeat wasn't on. I put in a CD, cranked the volume all the way up and put my DMM leads on the RCA jacks on the rear of the HU and it reads absolute 0 volts. With the unit having 4 volt preouts, shouldn't I be seeing 4 volts, or very nearly 4 volts AC? The only thing I can think that could be wrong is the preamp output circuit is bad. What else could it be?
Sounds like a dead preamp section if you aren't getting any output from any of the RCA outs. Is the switch on the bottom set to "norm" and not "eq/div"?
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
903
grampi
grampi
Cheyenne
bumpin buick
slater
    May 2, 2024
slater
    May 2, 2024
