What would be better
$100 a set for good components better look used but why would you want so much for the rears that you normally can't hear or need. Rear is for rear fill only. And your sub stage may cause damage to the rears over time
if you plan on running 4 speakers in the rear deck off that kind of power your sub stage is going to have to be beefy aswell and with a beefy substage its going to push and pull on those rear speakers and probably make theme exceed their mechanical limitations
Well he's fiber glassing them, so I'd assume he sealed the rear deck off so the sub stage doesn't destroy the speakers or distort the sound.
What i fi did seal it from the back ? would that be fine and i was wanting to run some tweeters up front but idk how i can run them if i have two door speakers on my radio and 4 speakers on the amp what would be better 6.5 or 6x9 speakers in the rear deck? and ill be running 2500 and up
southport2014
southport2014
Indianapolis, IN
mlstrass
vegang
vegang
