You're right, no needed constant source.First of all, he does NOT need a constant source as it will stay on all the time..Second, you don't want it on the remote wire, most remotes are only rated at @ a half amp or less..Third, you don't even need an acc or ignition source, all you need is an illumination wire to turn the lights on the remote knob on whenever your headlights are on..So find your illumination wire, either on the head unit or at the dimmer switch, and connect it there..What type of car is it?
When you say "most remotes are only rated at @ a half amp or less", are you talking about the wire, the fuse, or ___? All I'm saying is he can splice into the wire that runs from its switched power source to the amp, You're talking like the amp's remote turn-on will somehow be feeding this remote knob: Not the case.
