What wiring kit/ battery/cap help
antonyr123
9
uk
Im new to car audio and i would like to know what gonna upgrades would u need to run a 2x 8000watt/3000rms)(16000watt total/6000RMS) amps. whats the best wiring kits ect?
Cheers
Specs of amp
Specifications:
Output Power (14.4v)
(When bridging the channels)
1 x 8,000 watts Max (@ 2 ohm)
1 x 3,000 watts RMS (@ 2 ohm THD+N
1 x 1,900 watts RMS (@ 4 ohm THD+N
(When using both channels individually)
2 x 4,000 watts Max (@ 1 ohm per channel)
2 x 1,500 watts RMS (@ 1 ohm per channel THD+N
2 x 950 watts RMS (@ 2 ohm per channel THD+N
2 x 600 watts RMS (@ 4 ohm per channel THD+N
Frequency response 10 Hz ~ 200 Hz
Subsonic Filter Frequency Range 20 ~ 50 Hz (Adjustable)
Low Pass Filter Frequency Range 40 ~ 180 Hz (Adjustable)
Bass Boost Frequency Range
45 Hz
Input Impedance
67 Kohm
Input sensitivity
0.2 V ~ 5 V
Signal/Noise Ratio (A. Wtg)
1 Watt Reff.
>100 dB
Damping Factor
(100 Hz @ 4 ohm)
>120
Efficiency
82%
Total Harmonic Distortion (THD)
4 ohm loaded 1 Watt 0.20%
800w RMS 0.50%
80% of total 0.70%
Idle Current 2.4 A
Max Peak Current
240 A
Minimum Subwoofer impedance Each channel individually
1 ohm
Minimum Subwoofer impedance when in bridge mode
2 ohm
Power supply
DC 12V
Dimensions
(length x width x height) 60 x 195 x 832 mm
Four of the below subwoofers
Specifications:
Parameter
Data Unit Info
Nom. diameter
12 [inch] Nominal diameter (30 cm)
Vas
54.957 [Litres] Equivalent volume
Qts
0.807 Total Speaker Q-factor
Qes
0.905 Electrical Q-factor
Qms
7.339 Mechanical Q-factor
Fs
21.935 [Hz] Resonance Frequency (Free Air)
Sensitivity
90.659 [dB] SPL dB at 1W, 1m
Max Power
3000 [W] Maximum input power
RMS Power
1000 [W] RMS input power
xmax
20.32 [mm] Max excursion from centre at normal operation (one way)
Moving mass
278.9 [g] (Mms) Weight of moving parts
Disp area
0.0434 [m2] (SD), Effective piston area of cone
Disp Vol
1763.8 [cm3] Displaced volume = xmax x 2 x SD
Coil diameter
76.4 [mm] Diameter of the voice coil (Kapton 4-layer - 3")
Cms
0.1888 [mm/N] The stiffness of the driver’s suspension
Magnet weight
5102.9 [gr] Weight of the magnet (180 oz)
Re
1.785 [ohm] DC resistance (per voice coil)
Z
2 [ohm] Impedance of coil (per voice coil)
L
2.23 [mH] Inductance of coil (per coil @ 1 kHz)
Bl
27.529 [Tm] Magnetic strength (Motor force factor)
Recommended sealed enclosure
0.0623 [m3] (2.2 cubic feet)
Minimum sealed enclosure
0.034 [m3] (1.2 cubic feet)
Recommended ported enclosure
Minimum ported enclosure
0.0425 [m3] (1.5 cubic feet)
Krm
2 [m]
Kxm
2.58 [mH]
Rem
5.31
Erm
0.984
Exm
0.656
P max
3,000 Watts Maximum peak input power
P rms
1,000 Watts Maximum RMS input power
Magnet material
High density strontium-ferrite
Cone/dust cap material
Dynaflex
Surround material
Santoprene Rubber
Aluminium shorting ring
Yes
Heat sink
Yes
Mounting depth
282 mm
I got no idea what that shit means.. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
umm lol..give us the NAME of the subs and the amps..not 100000 specs.
ur gonna need a 300amp alt, 6 runs of 0 gauge to the back, 10+ BIG batteries....better yet add a couple more.
10+ BIG batteries you ****ing kinding me : / lol
ur trying to run 6000rms...thats gonna take a huge amount of power. ive never ever in my life heard of this brand. im not saying anything by that..just that idk anything about it. what car is this going in?
edit:the subs you linked me to are 1000rms..
are you that set on this setup?
Well seeing what it intails.. i really think i should of stoped saving long ago.. whats a good audio brand that mixs good sound and price ? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
idk if Fi has made a big impact in the UK but they make some ridiculously loud subs for a good price.
You can't buy Fi in the uk.. Unless ya import them.. i gotta say usa have good prices.. were uk are alittle slower on the drop
umm if you know someone in the US they could buy it for u and ship it to you. idk what brands ship to the UK. check out audioque, Fi, RE, DD, Treo if you wanna get loud.
thats a LOTTA power. Especially if you are new to audio. Try thinking a little smaller maybe?? Even with only 1500-2000w you should be enough power.
I'v heard 4 Fi's doing about 140-145dbs @ a show . They was cool //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif atm i have 2 apline type Rs on a boss amp
well 1 18" btl can break a 145 in a decent install..
those r's can get loud on a better amp. boss is umm....sub par?
no audiobahn is trash
well 1 18" btl can break a 145 in a decent install..those r's can get loud on a better amp. boss is umm....sub par?
Ok. idk i never asked the dude the dbs maybe louder idk..
my boss amp is BL3KD
http://www.sonicelectronix.com/item_6677_Boss+BL3KD.html
i buyed that amp off ebay for £160($320) and u can get it from usa for like dirt cheap //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
antonyr123
antonyr123
uk
antonyr123
