what tweeters with these mids?
southwest713
i'm looking to get some AA poly mids. i was thinking 2 in each door in door pods.
which tweeters or crossovers would i need to make it sound good?
i listen to rock/rap if that makes a difference
specs on mids:
Znom 4 ohms BL 5.43 n/a Cutout diam. 5 13/16
Re 3.2 ohms Sd 140 cm2 Outer diam. 7.00
Fs 46 Hz Mms 16 g Mounting depth 3 3/16
Vas 20.8 L Xmax 11.5 mm Weight 2.6 pounds
Qms 2.714 Spl 88 dB 1W/1M Voice Coil diam. 1 1/4 inch
Qes .501 Rec. Power 25-100 W Voice coil 4 ohm
Qts .423 Rms 100W Cone Curvilinear Poly
Le .05 mH
southwest713
southwest713
Houston, TX
MrSwiss
michigan born
    May 14, 2026
michigan born
    May 14, 2026
