What to use to cut bigger circles?
Qbenjamin
I have started preparation on my box build, but I ran into a small problem today. My circle cutter for my Dremel only goes up to 12 inches. I am building a box for a 15" woofer, so I need about 2 1/2 inches more diameter outta my circle cutter. Is there anything else I could use to get that perfect circle? I have the router attachment also, but I don't like cutting holes without the circle guide. Any info would be appreciated. Thanx, Quintin.
Jasper circle jig and a router. It cuts circles from 7" to around 53" in diameter.
Jasper and router are much much more accurate
Jigsaw works just fine, with patience and a steady hand
Plus you can pick up a jigsaw for 25 bucks, a router and a jasper would run you closer to 150+bits
CT
Qbenjamin
Qbenjamin
Braavos
Thieroff
