what to get ???
  • 4
Cooldood04
I would like to istall some 10" subs in my porsche 944, But I dont have a whole lot of cash. Is pyle a good company to get audio equipment from, because I found some 10'' subs with 800w max power 400w rms for $40.00 each.
If I did get subs with that power what size amp should I get???
What If I got some legacy 10'' 500w Or 12'' 700w subs Is this a good company? I only have about 300 dolars If i get 2 0f the 500w subs what size amp should I get, what If I got 2 0f the 700w subs
Originally posted by Cooldood04 Thanks for your opinion, but how should the size of the amp compare to the total watts that the sub can handle???
Well, getting an amp that is around the area of the RMS is always good- but make sure the impedances match up- example- Say you buy 2 DVC 4 ohm woofers, which are 500 rms, and can be wired to a 1 or 4 ohm load- you don't want an amp that does it's full power, lets say 1000 watts, at 2 ohms- and isn't stable at 1 ohm- it just doesn't match up.
you got a porsche but are strapped for cash?? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Cooldood04
Cooldood04
Bloomington Illinois
more_spl
