~The SeTuP~
paintball9908
If I were to get 2 12 in jl audio w7's, JL Audio XR650-Csi system, what 2 amps should I use to run this? Also, will I need an extra battery? Lastly, is their anyone out there who could walk me through what to do for installing? I mean like start at the head unit and go through which wire leads to what and the kind of wire.
You're going to need an *** load of power to begin with, and a lot of room. Then you'll need to look into a HO alt. and probably another battery.
Have you looked into other options?
Originally posted by paintball9908 you guys say it will be so much money... how much? Also, what do you suggest is just is good yet cheaper?
The 12W7 goes for about $600~$700 a piece here. The 13W7 will go for quite a bit more than that from my understanding.
Check out edesignaudio.com for the A series or adireaudio.com for the Brahma or respl.com (under construction) for the XXX.
All will compare fairly close to the W7, and around half the price.
paintball9908
paintball9908
Michigan
Aurorav8
Doxquzme
    May 13, 2026
