what to get? help...
  • 3
Matador
-= StillBumping =-
2,050
Ca
Sup guys, i need your help, i am either going to get 1 12'' or 2 10'' solobarics 4 ohm DVC L5s. however, i don't know which one! what would be better, i m thinkin if i get one 12'', i 'll prob get a vented enclosure, if i get 2 10'' i'll get a sealed one. what do u guys think? i like rap music mostly, n i want my subs to boom, but i don't want my car to rattle. or wat do u guys recommend? it's for daily booming driver.
also, i might need a new amp, mine is only 2x300 peak prob, so like around 300rms for both channels. what do u guys think of the JBL ones? prob 600.1
help me out here, i can't decide =(
I personally would get the 1 12" in the ported box. It will be plenty of boom. Plus you'll have the extra money saved from the second sub to spend on an amp. The JBL 600.1 will push the one 12" L7 very well. Very good choices I might add //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
...Good choices. All I wanted to add is that if you find yourself having to save for a bit before you can buy the JBL, then you can bridge your current amp for between 400 to 600 watts (depending on what amp it is) to your L5. That would help get you by in the mean time.
Take care and God bless you.
my audiobahn a2600e i think is a 2x300peak, so 2x150 rms. dat would give me around 400 to 600watts? cool. frraksure, wat do u think is better, one 12 or 2 10s? n in which type of box? the jbl600.1 shouldn't be too much power for just one 12 right? i think the 12 L5 is rated at 600watts rms. it's a 0.1% THD acceptable? if i bump the volume high, high, really high //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have installed a alpine sub and amp, using a line output converter it all works but the bass stays steady and does not change with the volume...
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
106
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
246
Matador
-= StillBumping =-
Matador
Ca
Matador
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
