what to do
Get a distrobution block, prefferably 1/0 guage that has at least two 4 guage outputs, and run 1/0 from the batt to the block. Then run a 4 guage run to each amp, and ground each amp at the same location.
As for the RCA's, have one set from the head unit going to one amp in the INPUT jacks, and then run an RCA cable from the OUTPUT jack of that same amp to the second amp's INPUT.
And if you were wondering about the REM, run one wire to one amp, then just have a second wire in the same amp's terminal that jumps to the second amp.
OK i hooked up power wires got a dist block 0ga in and (2) 4ga out. now for the RCA, hooked up one main from amp to hu and then from that amp got a Lil RCA cable, out put too second amps input. looking good.
now for the sub wire how do i do that do i just run each sub to each amp. or is there a spacial way
marcus...if you need help with your install .. hit me up. Also if you still need that box built let me know. I don't know if you saw pics of my install but i do everything myself...no shops for me mang.
marcusb419er
was from oh but now in fl
bonesninja
ThxOne
    May 13, 2026
