what the f**k?
OK, so we have established that you have a 1-channel (aka monoblock) amp and should wire four 4-ohm SVC (single voice coil) subs like this:
... which will make the amp "see" a single 1-ohm load.
You could also get four 2-ohm DVC (dual voice coil) subs and wire them like this to make the amp see a single 1-ohm load:
okay now i'm thinking about wiring 4 of these guys (ZX12D4) to the amp instead of the HFi's because i was misinformed
they are dvc 500rms 1000watt max, i can get them brand new for $50 each. 4 of these would be like having 4 of the diablos
Your the one who said its a 2ch, no? Its a Mono block.
maybe i put the wrong amp code in. i'm gonna run to my shed and check.......
...pp-am20001. idk if its the same or not but yeah its a monoblock idk why i wasn't saying mono. but how would it be safe to wire 4 ZX12D4's to the amp (2 of them for now)?
OK, do it. Get four 2-ohm DVC models. Wiring it like this achieves a 1-ohm load:
I couldn't get the specs page to load to confirm that your amp is capable of handling a 1-ohm load, so you need to verify that yourself.
Oops ... Are those SVC subs? If so, wire it like this:
Oops again ... The ZX12D4 is not the right model for your setup. You need the ZX12S4.
every time i post this i don't get straight answers. everyone only wants to talk about their system no matter what forum i'm on. i don't care about your system (no offonse if that bothers you for some reason). i just need some help!!!
I can't believe people are trying to help after the OP posted that crap.
He doesn't care about others' systems, but he wants others to help him with his. F that.
Well he said no offonse. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
OP, your just like i was for a while. Slow down on what you want to get now, and read around on here and think about your decision. because I shot myself in the foot after i learned that I just wasted money on a system thats no good.
No hatin, just trying to give you some insight. Think a lil more about what you want. You want to get 4 $50 subs? If your gonna spend 200 bucks than I would rather get a decent or good used sub for $200 or even cheaper.
Again no hatin here man
Yes, true ... this is the best response. People here can tell you what to get based on what you ask. But, once you are a more knowledgeable you'll probably wish you had waited and spent your money once you knew on your own what you really want/ need. Of course, even if you do that, and build what you think is the baddest system, the last one you'll ever need ... 2-3 days later you'll already have ideas for your next system!
cory51191
Cory
cory51191
Worcester County
cory51191
