hoodulum
i am going to be starting a build and thinking of getting a sundown saz - 4500d . these are the ratings
4500 x 1 @ 1 ohm
2000 x 1 @ 2 ohms
900 x 1 @ 4 ohms
TEST RESULTS SO FAR :
3100 Watts @ 1 ohm nominal rising to 2.67 ohms on 14.4v dropping to 13.6 volts
4650 Wats @ 0.25 ohm nominal rising to 0.71 ohms on 14.4v dropping to 11.6 volts
You will get more with a beefier electrical setup
5290 Watts @ 1 ohm nominal rising to 2.12 ohms on 17.9 volts (did not measure drop)
6930 Watts @ 0.5 ohm nominal rising to 1.31 ohms on 17.9 volts (did not measure drop).
I will definetaly be beefing up my electrical system. i cant figure out what subs to get?? i have 3 boxes for 12" subs already built they are each 3cubic feet each with a 3"x14" port. i was thinking mabe getting 3 1500rms 1ohm subs and wiring it to be a .67 ohm load. or get 2 bigger subs? my setup would be for daily, but i want it EXTREMLY LOUD. what are your thoughts??
i want the best quality. money isnt an option.
4500 x 1 @ 1 ohm
2000 x 1 @ 2 ohms
900 x 1 @ 4 ohms
