What speakers will go well with a Panasonic CQ-C8301U
ryanbssc29
I was wondering what coaxial speakers would go well with a Panasonic CQ-C8301U hu? The specs on the hu are:
CD / MP3 / WMA Playback
Removable Slide-Down Faceplate
Motorized Front Panel Disc Loading
Metal Finish Volume Knob
MOSFET High Power Amp (50W x 4 max)
SBC-SW (Super Bass Controlled Subwoofer) for Improved Soundstage Imaging
CD-R / CD-RW Compatibility
3DDM (3D Dot-Matrix) Display
High Resolution Graphics
Full-Motion Animation
Customizable Background Scenes
Upload Your Own Images from a CD-R
Download Pictures from Panasonic's Website
CD-Text and ID3 Tag Readout
Super Bright Blue Illumination with Dimmer
Multi-Mode Spectrum Analyzer
5V Front & Rear Preamp Outputs with High-Pass Filter
5V Subwoofer Preamp Output with Low-Pass Filter
7-Band Sound Quality (SQ7) Equalizer with Presets
Smoked Chrome Finish with Half-Mirror Display Window
Day & Night Design with Intense Backlight
3-Beam Hologram CD Pickup
One-Chip Digital Circuit
1-Bit Digital-To-Analog Converter
Multi-Stage Noise Shaping (MASH)
Digital Servo Optical Control
Track Scan, Search, Repeat, and Random Play
CD Changer Control
Blinking Security Light
Anti-Shock Floating Mechanism
Auto Loading Mechanism
18 FM /6 AM Presets and Preset Scan
Dual Auxiliary Inputs (one input takes the place of a disc changer)
Included Wireless Remote
Any help/suggestions will be apreciated. If nothing else reccomend some good brand names plz.
I think i prob want alot of sq since i have subs so im n no need spl. And my bad bout the cost i just forgot to include it i dont wanna spend over 200 for 4 of them, id prefer to keep it in the 150ish range but if i have to i can go up. any suggestions
you dont need to bump a thread that is on the top...
First 2 speakers is better for sound quality...
Second 200ish is good -- 300 is much better there are tons of options -- My custom component sets would be the most flexible to your needs as well as the best value, but so far as retail goes:
CDT, Rainbow, DLS, Boston Acoustics...... there are lots more... but those come to the mind first for the best value...
I think that you have a few options:
-Be on a strict budget and get ~$150 coaxails and run them off HU power.
-Spend $300 on comps/coax's w/ external crossover and run them off HU power
-Spend $150 on getting an amp/amp install kit & the $150 coax's, and have them sound the same, if not better/louder, than the $300 comps/good coax's on HU power.
-Ideally: Spend $300 on good comps AND $150 on an amp for them= $450(a little out of your budget maybe though)
There is an audio shop right there in Waveland that sells Diamond Audio and Memphis. Go by there and give those speakers a test drive. I think you would probably be happy with one of these brands.
I have not heard the DA coaxils, but the company seems to enjoy a good reputation and I would be surprised if the audio shop did not recommend them over the Memphis. It is certainly worth it to listen to them.
But listen to the Memphis as well. I know that Memphis has coaxils that have tweeters that can be "aimed" and I think they sound very good. They are probably a little cheaper as well.
Also, there is an audio shop in Slidell that sells Bostons in that price range. I have listened to them on the soundboard and they sounded good.
I don't know what kind of auto you have, but mounting depth may be a consideration. You probably want to get an idea of what your limitations are so that you don't spend any time considering speakers that do not fit.
Hold up. I just noted that you said you wanted to buy 4 coaxils. I agree with the others ---- do NOT buy two sets of crappy speakers. Buy one set of decent speakers. You are not really going to be able to hear the rear set anyway.
If he's running only HU power though, He'd be better off running a 4 speaker set. I also beleive that he would be able to hear the difference, otherwise I doubt decks would have faders as a mainstay. Some decks also have a front inmage enhancher also, which when turned on will turn turn on a LP crossover to the rear set, enhancing imaging while keeping solid bass with only speakers to work with. However if he plans on upgrading in the future my advice to him is to just start with crappi-er equip(entry level polk/infinity etc) to practice installing and see how things work, or just go all out and get a nice set of comps to run off HU power, and amp them later. But once he amps a pair of componets or nice coax's, he'll wonder how he ever went without an external amp on them.
Going off of my personal experince, I can say without reservation that adding the rear speakers made VERY little difference. This is in a vehicle running off of HU power. About all it has done has added rear "fill", which is barely noticeable. I am certainly glad that I did not have to sacrifice the quality of my front speakers in order to be able to afford two sets, considering the fact that the rear speakers were really a waste of money. Granted this may be vehicle dependent, but that is my experience.
I know of at least one very good use for the front / rear fader. I fade all power to the rear occassionally just to make sure the rear speakers are still working.
I see absolutely no reason to waste money experimenting with crappy speakers.
The cost savings between the speakers you are recommending (which are not that bad of speakers by the way) and most other coaxils that he would be looking at is not that great anyway.
Of course, this is assuming that he wants what he indicated, coaxil speakers.
Go with the best speakers you can reasonably afford up front. If you later feel that you need rear speakers, buy a cheaper pair for the back. At least this way you are certain to have front speakers that you can keep. If you go with the "buy four crappy speakers to experiment" route, you will end up with just that. Four crappy speakers. But, on the bright side, at least you will not be able to hear the rear crappy speakers.
So there.
So there.
"So there"- Lol gotta love it.
If the only reason you are using a rear fader is to be sure they are still working, you must not have a confident ear or be very confident in your installation. Also, I never directly said to buy crappy stuff... last time I checked most people didn't think of the polk db/infinity ref series that I used as examples as "crap". However, it isn't the brightest thing to do to go out and buy a set of infinty kappa's or polk momo's(just examples I know there are more speakers than that
Well I believe we are now in total aggrement. This young man should go down to his local audio shop that I know carries both DA and Memhpis coaxils, both of which have external crossovers (I am relying on my nemesis for the scoop on the DA crossovers).
This is what I recomended in my original post. In the future, I would request that once I post advice that no one else post questioning that advice. It only confuses the intended recipient. //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
In response to the fader / ear / install comment, my point is that the front speakers over power the rear speakers to the extent that the only way to be sure that the rear speakers are even pumping out any sound is to shut the front ones off. Now, if I fade all the way to the front and then add the rear back in I can tell some difference, but it is not significant.
BTW, please note that I never said that Infinity or Polk speakers were crap. In fact, I defended them, albeit half heartedly. They are just not my personal preference.
So, he can either go with the coaxils or, as others have suggested, the BA Z6's.
Thank you very nice.
ryanbssc29
ryanbssc29
Waveland, MS
SteelWheel
