What ported design would you use for this driver? JL 13tw5-3
NSTALN
Dismember
I'm curious what you folks would design for a ported alignment...JL doesn't suggest one. I was thinking 1.5cf tuned around 28hz-30hz.
13TW5-3
Free Air Resonance (Fs): 27.52 Hz
Mechanical "Q" (Qms): 11.230
Electrical "Q" (Qes): 0.511
Total Speaker "Q" (Qts): 0.489
Equivalent Compliance (Vas): 59.47 litres
One-way, Linear Excursion (Xmax): 9.7 mm
Efficiency (1W/1m)**: 85.87 dB SPL
Effective Piston Area (Sd): 98.256 in2
Nominal Impedance: 3 ohm
Power Handling (continuous): 600W
Thanks!
The ideal ported box for a sealed box sub is always giant and tuned really low. (Ideal model: ~4cf 20fb)
Looking at it in WinISD -- Tuning lower than 35 doesn't gain you much with a box that small. It gives you slightly more output at 30 and lower (rolloff is already steep, so it's low either way), but noticeably less output at 45-50. Plus, the size of the port will become an issue if you're trying to keep the box small.
Thank you for your input.
NSTALN
Dismember
NSTALN
Manchester, NH
THATpurpleKUSH
