What pair of 15"s for around $800ish
its been more then 2 days, but if you want it then ok, jeremiah25 on here used the hd3 woofers to set the usaci sb3 world record. They are very solid woofers, they will take a beating, I have a single 12 hd3 run off an american bass vfl400.1 @0,7 ohm load an it seems to not mind.
those amp will probably only put out 1800 rms
oh well....**** i guess he has to change his whole set-up....................
you don't have any fuggin clue what those amps will do. This is for his daily driver, he's not going ride around with the volume maxed out on his headunit or have the gains topped out. So unless you have somethin useful to add.........GTFO/STFU
bonesninja
bonesninja
Lima, Ohio
bonesninja
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
