What one of these 3?
KJThaDon
I have 3 12" kicker dual 2ohm cvx's in a vented box.
I also have these 3 amps to choose from
Planet Audio BB2400.1
Kicker 11ZX2500.1
AudioQue 2200
These subs are 750 RMS each so = 2250 RMS
I already have the big 3 - 0 gauge everything, a 250amp alternator and an optima D34/78 under the hood
What amp do you guys think will work out best?
If I run the kicker what will I have to do to not have it blow the subs?
Thanks
the kicker wont work well since youll be around 1.33 ohms or less than one ohm (depending on wiring)....unless u wire to 3 ohms
audioque, is one ohm stable and will give you about 2000 at 1.33 ohms. so i'd go with that one.
the BB planet audio would work well, and we all know the AQ amp will do amazing
---------- Post added at 12:55 PM ---------- Previous post was at 12:54 PM ----------
and your gonna need another battery in the rear to power it all up //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
So the kicker would have to be ran @ 3ohms then?. any idea what wattage that would put out then?
Any suggestions for a back battery, maybe a redtop optima?
Thanks for all the replies!
KJThaDon
KJThaDon
Westland. Michigan
BlactimusCrime
