What ohm load is this?
galacticmonkey
Wants a button like that.
I dont have my DMM, or else I wouldnt be posting. I have a 4ohm speaker on eac channel, then a single 8ohm speaker bridged on top of those. A friend told me to try it, so I did. I wasnt sure what ohm load it would be, so I went easy. Then after the amp was still staying cool, I cranked it up. After about 30 mins wide open, it didnt even feel like it was playing, so it might not be a low ohm load.
Heres a pic of the wiring. Anyone know what final ohm load the amp sees? Its not set to bridged, its set to stereo.
I'm gonna guess each channel is seeing 6?
you should series wire the 2 same speakers then parallel the third one and run the amp bridged.
2 Ohm Per Chanel On My Amp I Have 2 4 Ohm Speakers Per Chanel And 2 8 Ohm Speakers Bridghed = 1 Ohm Per Chanel On My Amp Sorry On My Spelling Im Shit Faced On My Phone
I meant between the sub and the comps. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It would be a rather large inductor on the sub and rather large capacitor on the comps, at a minimum.
It will depend on how you have the speakers crossed overed.It will be frequency dependant. Example:say you have a 4 ohm tweet playing 20,000 hz-3500 hz...a 4 ohm midrange playing 3500 hz - 100hz.....a 4 ohm sub playing 100 hz and below all wired parallel on the same channel that channel will see a 4 ohm load.
Now lets say you have a 4 ohm tweet playing 20,000 hz - 3500 hz......a 4 ohm midrange playing 5,000 hz - 100 hz.......... A sub playing 100 hz and below all wired parallel on the same channel that channel will see a 4 ohm load from 20,000 hz - 5000hz....a 2 ohm load from 5,000 hz - 3,500 hz....a 4 ohm load from 3,500 hz - 100 hz....and a 4 ohm load from 100 hz and below.
The reason in the 2nd example the frequencies between 5,000 hz and 3,500 hz is presenting a 2 ohm load to the amplifier is because Impedance is FREQUENCY dependant, there are two drivers reproducing frequencies between 5,000 hz and 3,500 hz.
If the 4 ohm speakers in your diagram and the 8 ohm speaker in your diagram are NOT OVERLAPPING the 4 ohm speakers will present a 4 ohm load, and the 8 ohm speaker will present an 4 ohm load to each channel because it is bridged , giving you 2 4 ohm loads on each channel , wich in turn equals 2 ohm stereo.....so the amp is running 2 ohm stereo.
galacticmonkey
galacticmonkey
Tampa, FL
Johnny Law.Lulz
vegang
vegang
