What ohm is this if u hook the positive and negative to the outside corners of the subwoofer ? Also my amp is an alpine 3539...bridged pushes about 40
  • 2
8ohm. That jumper in the middle puts the coils in series. There is no way to make this single sub a 4ohm load to the amp unless you only connect one coil (which is NOT recommended). You can either run the coils parallel for a final load of 2ohms, or run the coils in series for an 8ohm final load to the amp. in theory you'll see about 200 watts running an 8hm mono load on that amp.
Ok thanks for the info. I'm guessing 8 ohm isn't the loudest way to run this sub do you have any opinions on how i should run it???...i have another jumper wire I could use too.
You can: A get a sub that is 4ohm and run it on your amp. B you can get an amp that is 2ohm stable and run the sub with the coils parallel. C you can run the sub at 8ohms into your amp and get about 200watts of power.
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
196
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
166
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
820
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
929
Foxxxycoxxxy
Bass junkie
Foxxxycoxxxy
Foxxxycoxxxy
    Apr 27, 2024
audiobaun
    Apr 27, 2024
