What OEM interface should I get???
ace_800
Ok, so I am starting to look at upgrading my system in my Land Rover and since I can't replace the factory Nav unit or HU need a OEM interface. It appears I have the 300 watt harman kardon system so I can go with an Audiocontrol unit. I was looking at either the LC8i or the DQL-8 or possibly the JL Clean Sweep or the RF 3sixty.2.
I know the RF unit can be tweeked beyond what I need but would like some opinions.
Also throw the MTX Re-Q in the mix as well.
Much less expensive, and it appears if all you are adding is a sub, the Re-Q is more than sufficient, but is lacking an EQ besides for its bass enhancement knob.
I am using this because a cleansweep / 3sixty / audiocontrol unit is typically 2x as much
ace_800
ace_800
Okinawa, Japan
ace_800
