What Kind Of Sub Is This?
Tom Sederburg
18
STL
Can anyone tell me the brand or model # of the speaker in this picture?
Curiously,
Tom
Thanks for the info.
Oh hey, curious - would you say that speaker is one the the best for use in such a small space?
I was thinking about doing something similar to what he has going on where the armrest folds up to get some more bass in my car.
Later,
Tom
I vote no, you could find much better. If you have some specific space/needs you can share you might get some good suggestions
Okay, well here's a pic of the space I have in my car:
I measured everything out just to be sure you got the figures you needed to help me.
If you would like to know anything else please let me know. :)
Thanks,
Tom
It isn't a sub. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It is a base speaker though, isn't it?
If not, can you tell me whether anyone makes subs that small?
(I confess I am a bit confused as to what defines a speaker as a "subwoofer" exactly..?)
My system is just lacking "oomph" and I want to get the best quality bass speaker that can fit in the limited space available.
Regards,
Tom
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
So you have an 800 watt sub (1600 is a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
85
276
450
549
Tom Sederburg
Tom Sederburg
STL
shaneb
    May 19, 2024
    May 19, 2024
