What kind of enclosure would u recommend???
danteBirosel
I just got a 12" XXX (thanks trigger) and was wondering if u guys got any good enclosures that i can make that can go WOW. Size is really not an issue because i can fit more than around 5.15 cu ft already. I was thinking either a snail shell enclosure, ported enclosure which goes sub up port rear or ported enclosure which goes sub rear and port rear.
Also have a double baffle that will FLUSH my subwoofer. Looks clean and nice, and should it tight on that XXX. Would you guys recommend bracing???
What kind of enclosure i should make for this wonderful sub i have?
-Dante
2.5ft^3 tuned to 32hz. Double baffle. Corner bracing and side to side bracing. 42inch^2 port surface area. Port same surface of the driver, in your pathfinder rear alignment for SPL or aligned up for a mix(SQL).
Prepare for a massive amount of flexing on your rear window and roof. More than you already have //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
And a try out a snail shell also. Never used one due to the size requirment, but have heard good things. Woods not to expensive anyways.
tRiGgEr
danteBirosel
danteBirosel
San Diego, CA
tRiGgEr
