What Kind Of Amp I Need?????
Terrance9710
I have three Volfenhag's 12's wired into 2ohms. all three in a tri- 12inch box. So i need to know what kind of amp i need i was thinking of a 3000w Boss 2-ch or a Boss 2000w 4-ch. the Box have three terminals. So i need to know what,how many channels amp i need to push these three subs. Or should i just get two amps 4channles. Need help don't know what to get here. anyone!
How many ohms do your subs have. I have 3 12" subs in my truck and i should have gotten 8 ohm speakers and it would have been no problem. I bought 6 ohm subs and i had to disconnect one sub and run it to my rear channel and the other 2 subs i have wired in parallel running to my subwoofer channel. If i had got the right ohm speakers, i could have wired them all in parallel bridged off of one channel. Make sure your amp is 2 ohm stable too. You say its a Boss?? Check to make sure it is 2 ohm stable!!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
the subs are 2oms,4ohms,8ohms. And yes the Boss Amp is 2ohm stable. and what is parallel briged. So you saying i can push all three subs with one Boss amp. The subs are 500w rms. and 1000w max. If i get a Boss 3000 2-ch, will each subs see 1000w . And if i get a Boss 20004-ch how would that work. Let me know how many channles amp i need to get and how many watts. to push all three without blowing some...
Thanks~!!
Terrance9710
Terrance9710
Fayette, MS
Terrance9710
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
