Completely false.I doubt that there is No difference. the difference in SOUND is very noticeable going from 2V to 5V.
Assuming there is no audible noise with the 2V setup, then you will hear zero difference.Just like it says, what kind and how much of a difference would I notice going from 2v to 5v to 8v preouts??
Not true.I have "heard" that with a higher preout voltage that the amp wouldnt have to work as hard, and that I would get a stronger and cleaner signal which would make it louder. Is there any truth behind what I've "heard"?
Then you didn't reset the gain correctly (if at all)when i switched from 5v to 8v preouts..my bass was noticably louder....i mean alot.
The only difference would be if your amplifier had audible noise with a higher gain setting.So it is easier on your amp then, b/c then you dont have to turn your gains up as high?
The fact is that the only potential difference is an increase in the signal to noise ratio when going with a higher preout voltage. And, therefore, if you had no audible noise with a lower voltage...going higher is going to gain you nothing.Bump to the top......what kind of difference are we looking at guys with different preout voltages?? It seems different people have different opinions, what are the facts here??
No.I think his question is "Does gain level cause the amplifier to work harder/harder on the amp/ etc"
Do NOT change simply for preout voltage.Alpine of course has the 2v preouts...so would it be smart of me to sell that headunit and get one with a 5v or 8v preout, or should I just leave it since it sounds pretty clean to me right now?
Not if you have no audible noise right now.Will the sound be a lot cleaner if i was to go with an 8v preout HU ?
Yes.So really theres nothing wrong with low voltage preouts as long as its a clean signal? Am i following this correctly?
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gifIf your only reason to switch is the input voltage, then yes, stick with what you have.
