what is the normal temperature
I had the MRD-605 with the Ai-Net hooked up. In the summer it would reach 180 degrees F. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif There is no "normal temp"
So if you are bumpin away for 30 minutes or more you will find the fans cranking away. If it gets too hot, it will shut down. Forealz yo! //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
yeah im in az so when it starts at like 150 off the bat. just wanted to make sure it was ok. cause after like 1.5 hours it went into protect mode and wanted to make sure that was normal. thanks brosephs
Pattychak
Pattychak
phoenix
blackbonnie
