What is the best amp from best buy?
Badfastbusa
Wheelie addict!!!
i bought a kenwood 1700watt amp from there and it is shutting off when the volume goes up for a while and i am very unpleased with it, it hits my 4 10's hard before it shuts off but its not even getting hot when it goes into protect mode so i am thinking about taking it back while i still can, what would you guys suggest i swap it for? does best buy carry any amps that would be better than this one?
the model # for this one is:
kenwood 9102d
my subs are hooked up fine... 4 8ohm 10's, should be a 2ohm load.
i am looking for the most power that i can get from an amp from best buy. preferably one that is 1ohm stable but i haven't seen one from there that is 1ohm stable, ideas? what amp (rockford, alpine ect.) and what model of that amp would be the biggest bang for my buck, i have a little over $300 invested in this amp and i don't mind paying a little more if there is something else there that would be better?
my subs are hooked up fine... 4 8ohm 10's, should be a 2ohm load.i am looking for the most power that i can get from an amp from best buy. preferably one that is 1ohm stable but i haven't seen one from there that is 1ohm stable, ideas? what amp (rockford, alpine ect.) and what model of that amp would be the biggest bang for my buck, i have a little over $300 invested in this amp and i don't mind paying a little more if there is something else there that would be better?
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
maybe i am mistaken on my wiring... if you had 4 8ohm subs with all the positives together and all the negatives together wouldn't that create a 2ohm load? basically all the positive leads are put together and all negative leads are put together at the amp, not really but that is the best i can explain it. there is 2 +'s and 2 -'s on the amp but it is a mono amp so basically the extra positive and negative are just there for ease of use when hooking up multiple subs, so i actually have 2 +'s from 2 subs going into one of the + on the amp and vice versa for the -'s... hopefully that is understandable LOL
yes that is correct thank you... now what amp would you folks recommend? i want the best (highest powered rms) amp they have, that may actually be close to its power range. basically i am looking for what ever is the biggest baddest that they offer.
that kenwood's 2 ohm stable only, what load are you showing it?
There's an identical amp to that, but it's an excellon, and is 1 ohm stable.
I believe it's 1080rms @ 1 ohm cea-2006 certified.
they were going for ~$260 on ebay.
XXV-03A.
Never had a problem with my kenwood amps, they don't make very large amps, but the quality is awesome, and they do more than rated.
there are only 2 i see on there website for the rockford but usually when i go to diffrent ones they suprise you with diffrent models but here are 2 online ones.
punch 600.1bd 600w @ 2ohms $500 or punch 325.1bd 325w @ 2ohms $250.
i picked up a limeted edition punch 150 at cardomain a few months ago $300
check out the birthsheet on the amplifier section not to shabby for the price.
Badfastbusa
Wheelie addict!!!
Badfastbusa
Atoka, OK
yacob.naif
