what is the best 10" to get with 1000w@1ohm?
on 1000 watts, as long as you build a solid box, configured correctyl to the sub, it'll get pretty loud. as far as "flexing" your car, there is no way to tell that. if your install is good, and your box is right, you'll pound hard.
and if you are worried about space. the cone area isn't the only factor. if you have 1000 bucks or so, you could put a 16 inch focal k2 power in 2.5 cubes ported. you'd actually have to put it in closer to 2 cubes with displacement. point is, you have enough room for alot of 12's also. or 8's. a 10 is good too. not trying to talk you out of it, just 2cents.
Thanks for all the replies. The box is going to be behind a rear seat in a truck so thats why i wanted a 10. To allow more cubes and less mouting depth. I'm look for SQL and so far here are the runner ups: DD 2510, Fi SSD, Ae Av10, T3 TSS, Memphis Mojo. I haven't heard any of these so what's your vote?
actually, any of those will work fine in a good box.
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
jeepintn
