What is active?
8v shouldn't hurt, definitely helps cancel extra noise(whines and such). always had whines with my other decks. not so with the eclipse. no preout voltage is adjustable though, it's set in the deck.
That's funny.....I got alternator whine when I installed my Eclipse 8053 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif And to make it even funnier....I uninstalled a rated 2V deck that had zero alt whine //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Preout voltage doesn't affect alternator whine as that's primarily a function of the grounding (voltage potential differences) and not the preout voltage.
And preout voltage is adjustable.....with the volume knob //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I don't know...the amp manual said it would be too much. Looks like I am stuck with the pioneer.
Remember that you'll only ever get rated preout voltage out of the deck with a 0db test tone at full volume. With music, which is typically recorded at -6db (sometimes even -10db), you're looking at an average of ~2V output at maximum volume.
I'm presently running my Eclipse 8053 (8V outputs) into amplifiers rated to accept a maximum input voltage of 1.5V......and I do not believe I've ever maxed out the input stage.
Too bad it is not available new or I would most definitely go with the alpine. Do they have any "problems" like the pioneer had RCA problems and problems with the 960s ribbon breaking.
hmm, i've had a jvc sh707, and pioneer 740 and 960. and i had alt whine all of those. i had to install noise cancelers to rid it. but with the eclipse i got no whine(maybe because the zapco balanced symblink helps though:naughty: )
slim j
slim j
ca.com
Speedyd718
NorthFramingham
    Jun 30, 2026
