What hz is this
Just had a chance to play with the subsonic filter. Output doesn't change when adjusting from 10 to around 30 (guessing). Any other suggestion as to why it is flat on that section? There are a few sections of the song that play flat so I assume they are the same frequency.
how about 12Hz, without even trying to be loud, with 10-yr old Trunk Baffle subs, less than 300W RMS, and with a SS filter:
what this shows is that when you play low frequencies, you hear harmonics, not so much the fundamental. this was loud enough i could hear my vented kickpanel speakers flapping from the pressure. the car is pretty well sealed up.
I can hear 25hz and up just fine.......it's that 20 to 23hz shit that scares me though //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Thats where my truck peaks. Its awesome when you can play that low and not be worried about it.
When I had my van, I found out with with enough cone area and power, you can DEFINITELY hear the air wooshing around you at 8hz.
mudflap91
mudflap91
Florida
galacticmonkey
