What guage to use????
4 gauge is what I would go with.
The gauge also depends on the length of the setup. If you have your battery in the back of the car then your gauge does not need to be as thick and if you drive a long suburban with a 20 ft power cord it would need to be thicker all things being equal.
ditoo... 4 gauge from batter to distribution block.. then 8 ga power cables from distribution block to amps... then the amps would require the same gauge wire to be grounded with(8ga.)..
(1) 4gauge wire(length from battery to distribution blocks(close to amps)
(2) 8gauge power cables (length from dist block to amp)
(2) 8gauge ground wire
nasoccerplayer
nasoccerplayer
Chicago
jaboran
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
