What ever is powerful
manoli337
Hello, i would like to know what kind or witch loudspeaker can hit 140- 150 dB.with a wattage of at least 25 000 watts(rms) but a great thing that gives a punch in the breathing!
Not like a vibration, really like a shot in the heart
im really lookink for quality
and also please if you found me the powerest things like; amplifier, sub, LOUDSPEAKER and things like that , i will be reconescent to you
thanks you for your help!
troll?? or not troll? your post is so confusing.
---------- Post added at 09:02 PM ---------- Previous post was at 09:01 PM ----------
think at this point you need to consult a local shop, to gain some info on how basic speaker systems operate, ant the power required.
25,000 watts? you could run 25 ia deathrows....or 10 ia wardens with 25,000 watts. the real kick is running well over 50 ia 187's. I mean you better get yourself a full size van or school bus and hollow that ish out. you might be able to actually set some records with that much wattage. but you will spend over 5,000 dollars alone on amps and 10,000 on sunwoofers to meet that.
I would start off by getting 3 stetsom 7k2 amps. or you could go with 5 sundown saz-4500 watt amps.
then get a custom enclosure......but look to spend about 5,000 for a box because a box for 50 ia 187s or even 25 is deathrows will be costly....
what I am trying to say is to run 25,000 watts car audio system you better be willing to spend at least 15,000 dollars.
manoli337
manoli337
quebec
splwj47
NorthFramingham
    Jun 30, 2026
