LOL nevermind... I found this information about Antarctica just now...You really live in Antarctica???
says he lives in antartica. not antarctica.lol. ficticious ice.LOL nevermind... I found this information about Antarctica just now...
"There are no permanent human residents and Antarctica has never had an indigenous population. "
The average range of human hearing goes from 20Hz on the low end and 20,000Hz on the high end. Of course there are exceptions but that's the range which is the accepted average human's audible frequency range.yea its a class d amp. can anyone explain it better?
so the amp its self is not able to produce output for anything higher than 250hz? how is that? i thought maybe it was referring to the low pass crossover built in the amp. so you mean if i hooked up a set of midbass to it, the amp wouldn't be able to output at all because its above 250hz?The average range of human hearing goes from 20Hz on the low end and 20,000Hz on the high end. Of course there are exceptions but that's the range which is the accepted average human's audible frequency range.
Your amp produces output from 17Hz on the low end up to 250Hz on its high end (the reason that it was assumed you were talking about a Class D sub amp).
17Hz, obviously, is a bit lower than the accepted average and that's the lowest frequency at which your amp is specified to produce output.
250Hz, which is pretty solidly in the frequencies commonly termed "midrange" is the highest frequency at which your amp is specified to output sound.
Knowing that, as well as knowing that frequency range isn't anywhere near the accepted average hearing range, is what tells us that your amp is specifically designed for powering subwoofers.
Because it wasn't designed to reproduce any frequencies higher than that.so the amp its self is not able to produce output for anything higher than 250hz? how is that?
It will be able to output up to 250Hz, according to the specs you've given us, and isn't particularly suited for anything beyond that. Technically you could connect some mids to that amp but anything higher than the 250Hz cutoff would be lost and you'd be pretty upset with the results, I'd wager, since tweeters wouldn't pick up the slack until somewhere considerably higher than 250Hz.i thought maybe it was referring to the low pass crossover built in the amp. so you mean if i hooked up a set of midbass to it, the amp wouldn't be able to output at all because its above 250hz?
Okay. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifoh yeah i live in virginia not antartica lol.
ok well i see what you saying, but i was getting this from a best buy product slip description. i just looked it up, the same amp says 20hz-20khz, so really this amp could reproduce all of the sound spectrum that we as humans are able to hear. btw this was the same class d amp.Because it wasn't designed to reproduce any frequencies higher than that.It will be able to output up to 250Hz, according to the specs you've given us, and isn't particularly suited for anything beyond that. Technically you could connect some mids to that amp but anything higher than the 250Hz cutoff would be lost and you'd be pretty upset with the results, I'd wager, since tweeters wouldn't pick up the slack until somewhere considerably higher than 250Hz.
ok well i was just using this alpine MRP-M650 as an example. the one that does 600rms at 2ohm. im sorry but im just not getting it.Okay - let's try and make this a bit easier for us to help you to understand.What amp are we talking about, specifically? (brand and model # would be a great help here)
oh ok, well bestbuy sucks at life, they listed the wrong stats. i was thinking everything was wrong because they were saying you can bridge a mono amp //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif. i think i understand it now, different amps reproduce different parts of the sound spectrum. one more question, if class d are the main amps for subs, how come i see some people run 2 channel a/b amps for their subs? im guessing they have a crossover for low pass as well?Using Crutchfield as a reference I found the frequency response for that amp listed as 20Hz to 200Hz.
It's a Class D monoblock designed for subwoofer usage and nothing more.
You wouldn't want that for midrange duty, for certain...
Class D amps are preferred for driving subwoofers because they are generally more efficient than Class A/B amps but at the sacrifice of lessened SQ. For bigger wattage demands most users prefer the lower current draw of the Class D units over the larger power input demands of Class A/B amps.oh ok, well bestbuy sucks at life, they listed the wrong stats. i was thinking everything was wrong because they were saying you can bridge a mono amp //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif. i think i understand it now, different amps reproduce different parts of the sound spectrum. one more question, if class d are the main amps for subs, how come i see some people run 2 channel a/b amps for their subs? im guessing they have a crossover for low pass as well?
