Foote
Ok. So, I heard a squeal. was told it was "indicator" squeeling on the brakes. So I got some new pads...took off the tire; put the new pads on. I bled the brake fluid out of the caliper in order to help compress the cylinder thingy. Then, I put the pads in; reattacthed the break line...then did the same on the other side...
Now, I turned the car on and hit the breaks a few time..it felt pretty loose but I wasnt sure. I kept and kept and kept pumping it but it didnt get tighter. So, I drove it down the road and theres like no breakage. I can push it in with very little resistance and it doesnt slow the car down; except just a bit. If I press REALLY hard it stops the car decently. ...So thats the problem now. The squeel stopped. But the brakes arent really brakeing.
To fix this, my friend tried "bleeding" the brakes. I'm unfamilar with the process or what to do or how it works. But he said it gets air out or something. He did it on 3 of the 4 tires. Whatever he did...somethign like unbolted something while i held the brake down then re tightened it... repeated on 3 out of the 4 tires...the last one he said it should be fine since with the back wheel off, with the brakes pressed you can see it moving or something.
Then we put more brake fluid in it; put the tires back on and pumpped it up and stuf again...and got back on the road...did the same thing. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Any tips? My gf is really getting upset with not being able to drive it. So quick help and good advice would be really appreciated. Absolutely not enough money to take it to a mechanic. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Plz help.
Thanks.
Oh more info: The car is a 1993 GMC Safair XLT vortec one...and..the problem seems to be with the front brakes.
Thanks.
