udmm54
Hey guys Im using a PAC OEM 2 loc to hook up my stock head unit to my amp. But im wondering where should I hook up my REM wire to? The LOC says this
The
OEM-2 provides an amplifi er turn on signal. To use, connect the blue/white wire on the OEM-2 input side to one of the positive speaker wires or to any source
that provides 5 volts DC or greater. The blue/white wire on the output side will provide 12 volts to turn on the new amplifi er. Connect the red (+) and black (-) wires
on the input side to switched vehicle power and ground. Adjust the output level controls as needed using a small screwdriver
I wont be using one of my rear speakers(since the other rear speaker leads will go to rcas for a future sub), so can i just connect the Loc turn on to one of my unused + and - speaker wires? thanks
A01: Yellow/Green: Radio Switch
A02: Yellow/Red: ACC (Main stereo power supply)
A03: Green/Red: Radio Remote Switch
A04: Red/White: (Security Input)
A05: Pink: Right Rear Speaker +
A06: Blue/White: Left Rear Speaker +
A07: Green/Yellow: Front Passenger's Door Speaker +, Right Tweeter +
A08: Green/Black: Driver Door Speaker +, Left Tweeter +
A09: Red/Black: Lights-on Signal
A10: White/Green: Constant Power
A11: Brown: Radio Remote Switch Ground
A12: Not Used
A13: Not Used
A14: Not Used
A15: Blue/Yellow: Right Rear Speaker -
A16: Blue/Black: Left Rear Speaker -
A17: Gray: Front Passenger Door Speaker -, Right Tweeter -
A18: Light Green: Driver Door Speaker -, Left Tweeter -
A19: Red: Dash Lights Brightness Controller
A20: Black: Ground
The
A12: Not Used
A13: Not Used
A14: Not Used
A20: Black: Ground
