what distribution block to use?
armstrong
lets poop together!
ok this is a newb question, but i need some help. i'm running 1/0 to my sub amp and i'm going to be running 8 gauge to my component amp. so would that mean i need a distribution block that has 1/0 and 8 gauge inputs and 1/0 and 8 gauge outputs? if so, then that's a weird combo and i haven't been able to find any like that.
You don't need a distro block if you are going to be doing both a 1/0 run and an 8 gauge run. A distro block is to take one large power wire and split it up to multiple amps.
Run 1/0 ga. from batter to distro. and then a 4 ga. to each amp. That sub amp is fine with 4 ga. power.
So get a distro. block with 1/0 input and two 4 ga. output
run 4 gauge to my 2 channel speaker amp? so i don't gotta get another wiring kit for my 2 channel amp?
I thought you already had all the cables...take his advice. 1/0 to the trunk to a FUSED distro block. Two 4 gauge (or a 1/0 gauge and a 4 gauge) to the amps. The 4 gauge cables have to be fused on the distro block because they are smaller than the 1/0 gauge and have no fuse small enough to protect them.
let me get this straight, i need a distro with ONE 1/0 input and two 4 gauge outputs? wouldn't 4 gauge be too big for the 150 watt 2 channel amp or is that ideal? also, what about the grounds? need a distro for them to or no?
armstrong
lets poop together!
armstrong
ohio
armstrong
NorthFramingham
    Jun 30, 2026
