What did I do wrong? Why isn't it loud?
Justinw303
[Space for Rent]
Alright, I've been laboring for weeks to get my sister's system hooked up and pounding. She has two 12" Infinity References in a sealed box, around 1.25 ft^3 per sub, powered by a PG Xenon 600.1 amp in the truck of her '95 Pontiac Grand Am, facing the rear. I calcuted the gains should be set at about 17 volts or so, so I set it and put in a CD and... very quiet bass. The subs were clearly moving and I was getting some nice (although possibly clipped) excursion, when I sat in the car it sounded like some factory 6.5's in the back.
What's wrong with it?
Ok, when I wired the sub into the box, for each sub there was a round wire and a squarish one. I couldn't remember which was positive/negative when it came time to hook up to amp, so I tried it first with the round one as positive, and got no sound, so then I made the square one the positive and it worked, so I just did the same with the other, so I'm assuming they're in phase.
wow, sounds like.... you should stop installing.
Phase means (in this case) that they are wired so that one is "pushing" and one is "pulling" effectively working against each other. Give it a shot, try and reverse them. How do you have them wired? To what load?
what is phase? i have it on my amp i just keep it on 0degree its seems fine
'in phase' is when the subs both are working together (both move in and out together)
'out of phase' is when one moves out when the other moves in, effectively cancelling eachothers waves out.
They seem to be operating together... They are single 4 ohm sub, and I have each sub wired directly to a "channel", then the channels parallel inside the amp so its a 2 ohm load.
also, if your HU has a phase feature, switch from 180 - 0 or vice versa to check.difference should be dramatic
Yeah it has a normal and reverse phase, I tried that, didn't hear much of a difference, but I can't remember if I had it up very loud when I did this... I mean, I can heard bass coming from the speakers, but just not in the car...
Justinw303
[Space for Rent]
Justinw303
Silver Spring, MD
Kickerkitty
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
