What could be going on?????
all i could say is check wiring. or maybe check the options on the amp i have the cerwin vega 1000, and it has options like mono, stereo.. and all that so just make sure its set correctly with the right ohm configuration. is it an aftermarket head unit? or factory head unit? sometimes people install LOCs and forget to turn it up.
Wiring couldn't be more simple, i'm sure it right. It's a mono amp. And my head unit is an alpine cda 9825. Whats an LOC.
your amp is 2ohm stable? and your vc config on your subs? how do you have them wired? nvm loc, its used when you have a stock radio.
Yes its two ohm stable. I have the + from the amp to the first sub + then of that to the next sub+. Same with the ground.
smokeum99ta
smokeum99ta
sourthern, MD
smokeum99ta
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
