What CF and tuning is this box???
I am not sure of the length of the back port wall I would need to remove subs to take that measurment. Yes 45's in all 4 corners plus 1 where the port makes its 45 bend. Bracing is only one 1/2" dowel rod. Subs are 2 re mx 12's trying to figure out what cf and tuning I want for my new box that will use 4 mx's.
i used a program, no idea how accurate it is.
i entered everything he gave, then added port length until it made sense. for example with 0 port length it was tuned to like 67hz or something, add 10 port length it was idk 45hz, once i got to 15 port length it started getting somewhere, it was 35hz, but box size was some random #, so they had to build the box size right at a certain # or slightly above to account sub displacement. once u hit like 17 or 18 port length it got to be a little over 5 cubes and it was 33-34hz tuning, so the objective of the box must be 5 cubes at 32-34hz tuning.
best i could come up with, granted the program is accurate that is
if im wrong sorry was just a guess with what info i had
I'm trying to help you here. In order to help we need to know the length of the port. Also what size sub(s) and what kind are going in it. Answer these questions and we can answer yours completely.
bhsaudio
bhsaudio
kingdome
RAM_Designs
